distribution strap
16 years 5 months before #6824 by manual-mecanica
Manual-Mecanica Response on the Re: distribution strap
Hey and look, not necessarily the problem is with the engine, because as I told you the problem it can be with the sensor or actuator, if you do not know these terms I recommend that you read something, well in short the safe strap is burst for lack of maintenance or because the tensioner was not adjusted as it should.
16 years 5 months before #6851 by manual-mecanica
My girl, they cannot tell you that they have nothing to do with the Correa, since to change valves or repair them as they tell you they have to do or if, take out the distribution strap, now we wanted to check it neither the belt nor the tensioners, and they are trying to do the fool Tensioner a fixed bearing and the cams, so something has to be moved, now how your passes the marches of the car has nothing to do, at any point the gearbox affects the belt, but 0 in no case, now as Yandra says, the light of check is turned on when you open the contact and should turn off when the vehicle starts if it does not do so (it does not Any other questions just ask, or scribes to the mail I think that is mine and that of others.
