distribution strap
16 years 5 months before #6809 by manual-mecanica
Manual-Mecanica Response on the Re: distribution strap
Hello Sabata, hey because you do not write any tasting directly to the house to see if they recognize you something of that damage since you did not have the kilometers traveled check if you did the newspaper reviews and read the owner's manual well to see if it tells you something, in total try it costs nothing, if you did all the periodic reviews you have enough in your favor.-
16 years 5 months before #6810 by manual-mecanica
With the light on the check, you should make the computer to see what error code is giving you and thus be able to solve some cars when extinguished automatically do the reset and that is why then you have no code.
16 years 5 months before #6816 by manual-mecanica
Hi Sabata311, look at the check turns on to let you know that something is wrong, but only in the fuel injection system or in some cases refrigeration system, it is now advisable The belt, if they already put hand once before the cut, the tensioner bearing may not be correctly installed. Here in Chile you have many guarantees about that, I don't know where you are from, so not if they will answer, but you can ask you some normal mechanic and show you the cut strap if you have it and they will tell you because it is cut there sistincts types of cracks or failure of the isma strap, test and let me know,
16 years 5 months before #6820 by manual-mecanica
:( I am from Colombia.
The mess is that they do not want to recognize the damage, because they say that what they repaired was not the engine, although they did have to lower the engine to make the repairs to my vehicle. I will try to do it through the insurer. Of course they told me that the damage of the belt was due to poor handling of the gearbox, but in fact I try to be very careful with the vehicle, however, I will do it.
Thank you...
16 years 5 months before #6823 by manual-mecanica
Hello, look that witness is turned on every time you put into operation of the car because the ECU does so, because let's say that it is a revision, either in short it is activated after this functionano the car or if it is activated at the beginning and does not go out it is because you have a problem with the engine, or with some electronic component either a sensor or an actuator ...
