Sis. Electric Renault Twingo
16 years 5 months before #6708 by manual-mecanica
Sis. ELECTRICO RENAULT Twingo posted by Manual-Mecanica
I have a Renaul Twingo, I have stopped working the signals and the Pica Pica, however the ethan ok fuses.
Will anyone have a diagram or electrical circuit manual?
Many grace
16 years 5 months before #6715 by manual-mecanica
Manual-Mecanica Response on the Re: sis. Electric Renault Twingo
Check the emergency light interruptor, it may be badly imprisoned
16 years 5 months before #6736 by manual-mecanica
The red button of the beacons? ... am I going to check it, but at first glance or rather mechanically it gives the impression that it works ...
Thank you
16 years 5 months before #6759 by manual-mecanica
did you check the relay, and the button inside? What year is your Renault, I want to have a BSI to command
16 years 5 months before #6779 by manual-mecanica
Yesterday I check the beacon button and it's fine (with a tester) .. I thought it could be some relay, but I have no idea where it is, what it is. The Twingo this is from 96, and this is its first failure in 12 years ...
I have searched for the electrical scheme but I have not found it anywhere; If you tell me where is the relay barbaro, about BSI, I have no idea what is ...
thanks
