Sis. Electric Renault Twingo
16 years 5 months before #6812 by manual-mecanica
Manual-Mecanica Response on the Re: sis. Electric Renault Twingo
The relay of the flashing are usually at the rifle, if you do not find it Ally looks under the board inside the car where the fuses are, in the user's manual or in some of the tapas you appear, they are called Hazar Sipo, not cats.
16 years 3 months before #7355 by manual-mecanica
Hi Giacummo, I have read that you were trying your Twingo beacon switch. Well I have a 2001 Twingo and I have spoiled the beacon key in a motor vehicle. He got out of his place, being under the torpedo. You could explain how I can change it. Try up and by air controls but I don't reach it.
I thank you very much in advance !!!!
15 years 10 months before #9301 by manual-mecanica
Hello! Have you been able to solve the problem of pica pica and beacons of your Twingo? The same thing happens to me in mine (also model 96), and I already checked the button and the fuses and they are fine ... greetings and thanks!
15 years 10 months before #9328 by manual-mecanica
Manual-Mecanica response on the Re: Re: sis. Electric Renault Twingo
I pull up until it came out .... The operation is not very technical, but walked.
Regarding the problem, it was a front signal cable and passed in front of the radiator, after a blow (shock), stop walking. Well, the cable in question eventually towards land and burned the device (the relay). That was the problem.
SLDS.
