Chevrolet Optra left front wheel noise
14 years 4 months before #19585 by manual-mecanica
Manual-Mecanica Response on the Re: Noise left front wheel Chevrolet Optra
Friend, as I said before, take your Chevrolet OPTRA and take it to a chassis washing after it lets dry and thus spray the entire bottom, especially where the noises are ... (spraying is an oil that apply with a pistol with pressure, .... Holy remedy ... luck
14 years 4 months before #19592 by manual-mecanica
I will do it, I will continue your advice ... What if I tell you is that here in Venezuela for these purposes a product called graphite is not I know if you refer to and do so as follows (according to what I have seen) they take the car they handle you with a diesel compressor and then make water to pressure after this (without letting it dry) they put the graphite ... and that is all .. greetings..
14 years 4 months before #19651 by manual-mecanica
Good, checking with all the information provided by you and the companions panelists. I deduce the following:
1.-THE OPTRA (at least the one here in Venezuela) is front traction
SOUND
OR CHOCK THAT WAY (OF GET TO DO IT IS DIRTED BETWEEN THE PILL
14 years 3 months before #19654 by manual-mecanica
Good afternoon ... I just removed (Friday) my Optra of the Chevrolet and the tests done to him were the following (and still has the noise)
1.- Monday: a new plateau (nothing continuous noise) was placed
2- Tuesday: a left full tripoid was placed (nothing is noise)
3.- Wednesday:
a hydraulic box was placed (nothing is noise) and it was applied fat to each screw and even the shock absorbers. They met me for Tuesday to try replacing the base that is under the air filter.
Greetings and help:(
14 years 3 months before #19665 by manual-mecanica
Good night Alfalfalf22. That type of car has metal washers that serve as a joint between the chassis and the cradle of the engine.
If they are not placed, greased and with the correct tightening of the screws, the safest thing is that you notice creaks.
Although it seems a bullshit that problem took my dream a few years ago with an Opel Vectra 2.0i, which after all is the same dog but with different necklace.
I hope you are lucky ...
