Chevrolet Optra left front wheel noise
16 years 2 weeks before #8294 by manual-mecanica
Manual-Mecanica Response on the Re: Noise left front wheel Chevrolet Optra
Dear, thanks for answering, the pills had already reviewed them, and they are ok. The noise is not theirs ....
The noise (rather crunch as if it were grinding stones) that I think it is motor support, it is not of the wheel but of the izqueirda front, it is more when it sounds I can feel a vibration in my support foot, the brijudo does not last more than 2 seconds and it is always when the car walks, for example if brake in a semaphore when it walks again, but then it sounds again, but later it sounds, but then it does not sound. And the best way to explain is as if he were grinding stones a
! Cro Croaj! It is when one starts the car and it makes the front raises ...
the noise of the pastels that you think it could be, he tube it with a corsa and as you say when checking the insurance of the pills it takes off, but that noise of pills appears when passing through potholes,
this other noise does not sound with the potholes only when starting or resuming the march.
Thank you very much for your answer, it is the end of week I will check the supports to have if I pillo the noise that has nervous ...
the noise in the crook of the shock absorber tomorrow in the morning I will take him to the workshop, today I could not for the work
greetings.
14 years 11 months before #14715 by manual-mecanica
Hello:
Yesterday I read the noise forum at the Chevrolet Optra wheel, I had the same problem about 1 month, after reading the entire forum, I convey the part of the brake pillings, well, I will tell you that today I went to a service and I made a chassis washing and then sprayed, it is an oil that applies to all the chassis, I left the noise and the noise was eliminated. Data to the friends of the Chevrolet Optra, greetings from Chile :lol:
14 years 11 months before #14717 by manual-mecanica
Hello:
14 years 11 months before #14722 by manual-mecanica
saves the noise you say of being of rubber or czech bushings the tray and di does not take off the game in the stabilizer bar plasters there should be the problem, or you have something simpler, lubricates these rubbers but of one in one so you will know what is the one that sounds when the noise disappears.
14 years 11 months before #14771 by manual-mecanica
The theme of noise was complicated, but reading I think that the change of all the tires (torsion bar, stabilizer) and a good lubrica to the front train was left as new ... greetings
