Auto does not start
16 years 2 months before #7572 by manual-mecanica
Manual-Mecanica Response on the Re: Automobile does not start
Well, I tell you that I have been mentioned in the amount of air, the carburetor has no electronic device, everything is mechanical. It has a vacuum pump. The air mixture is done in the carburetor venturi or below in the admission multiple? They have told me that it can be a mass of air mass, since in the multiple if there is a sensor. It also tells me that even if there is spark plugs the starter module may be damaged. Depending on whether the starter module is damaged, there is no sparkling in the spark plugs, will this be true? Gracais for your help.
16 years 2 months before #7588 by manual-mecanica
If there is high tension output in all spark plug wires and is intense blue and with good click the ignition system is correct, does the starter engine be good? Because if it has low speed and little power it absorbs the battery current and generates little spark power in the ignition, do you have any antirobo alarm system? Sometimes these systems are blocked and do not allow the start of the engine even if it seems to be correct is a complicated issue by not having the vehicle by hand to be able to review it, in short I would insist with reviewing the compression and the point of the distribution again and the point of the ignition and the ignition point to see if I find any variation, sometimes one or two teeth usually jump and generate problems lucky and keep it out of what happens.
16 years 2 months before #7617 by manual-mecanica
Let's see, look first to concentrate the crracteristic of your car, your vehicle is carbure with electronic ignition? Or is mono point monkey?, In response to your questions, the fuel and air mixture is done in the venturi inside the carburetor and there passes to the multiple of admission, with respect to the second, a defective ignition module does not allow the power to pass, the current enters the distributor but does not go out towards the spark plug cables, the vehicles do not leave.
16 years 2 months before #7618 by manual-mecanica
Tell me the model brand and year of your vehicle to save the technical data, if you have a nissan the most caused scheme the ignition module fails you usually happen.
1 year 5 months before #54469 by manual-mecanica
Manual-Mecanica response automobile topic
Well generally it will not prevent a car starting car. However, it could affect engine performance and cause problems in the general functioning of the vehicle, such as a decrease in the power and fuel efficiency. It is important to solve any obstruction in the exhaust system as soon as possible to avoid major damage and guarantee optimal car operation.
