Auto does not start
16 years 2 months before #7550 by manual-mecanica
Manual-Mecanica Response on the Re: Automobile does not start
If, as you say the compression and ignition, they are correct to disconnect the gasoline pump and plug and with the carburetor at its correct level and with clean and dry spark plugs try to start it, if you do not turn on, give it a good stretch to see what happens, keep me informed luck.
16 years 2 months before #7554 by manual-mecanica
I tell you that yesterday I tried to start it pushed but neither did it start, I don't know what more could you be grateful for some tips for motor starts (secrets, tricks or any tip). Thanks for your help
16 years 2 months before #7555 by manual-mecanica
Look if when you push it, make sure you have good compression and if the valves have their right light, it is a very strange case but without being able to review it it is difficult to be able to arrive at an acceptable solution, it controls well the point of the distribution as well as the ignition point communicate any novelty a hug.
16 years 2 months before #7559 by manual-mecanica
Hello look, it is as Jal says, your case is complicated without having the vehicle to be able to check it, now, you are sure that there is a spark and not cut in the spark plug cables? If the spark plugs come out wet, it is because there is no explosion, and it will only occur, if the amount of air is not adequate, the comprehecious is low or does not exist or lack of current. working. The engine starts and does not keep? Or never make it start?
16 years 2 months before #7567 by manual-mecanica
Hello, for what you comment in your tests and they are fine. Take that when starting the current of the coil. Berify if the exhaust gases come out. This correct. Fix with the air entrance to the carburetor (carburetor base) .Saludos
