Recale and not start
14 years 10 months before #15434 by manual-mecanica
Manual-Mecanica response on the Re: Recalent and does not start
hi how are things.
I see that you have gone well with the disarmament of the car. I imagine that you have disarmed as I gave you some indications, disassembling the oilcard the front cover of distribution and all the corresponding accessories. The best way to learn is this, disarming, but do not adventure to think that everything you do is fine, in the face of any doubt, you write so you have no problems later. Another thing, I hope you release the dentated sectors of the camshafts because one of them has a piece that is open with the camshaft sensor.
luck...
14 years 10 months before #15438 by manual-mecanica
Do not touch the camshafts or the valves and did how your victor told me, what does not remove the motor of the car because I have no means for it.
[IMG
So is this time, we'll see how follows. Greetings
14 years 9 months before #15792 by manual-mecanica
The Corsa is running, this morning I finished mounting it and I have started it, now I have to remove the radiator again because when the thermostat opens it loses water.
I have changed the butt joint, retain the plain plane and new thermostat.
Greetings
