Nissan Micra, 2005, lacks strength.
14 years 10 months before #15602 by manual-mecanica
It is not necessary to cancel the EGR valve you have to take it out and clean everything there is for there (Carbonilla)
14 years 10 months before #15603 by manual-mecanica
And if the problem is that the membrane is broken or something? How will I know if it is broken instead of dirty?
Thank you very much again.
14 years 10 months before #15604 by manual-mecanica
First the first check all the filters or better if you do not change them so : KISS:
14 years 10 months before #15605 by manual-mecanica
They are all changed, the air changed it 3,000km, and that of Gasoil makes 10,000kl
14 years 10 months before #15640 by manual-mecanica
This car carries the Renault engine and a very common problem in them is that the EGR valve is filled with carbon and does not close the problem correctly. This valve cannot be canceled because it would give failure to the control unit. Normally with a good cleaning the failure would be removed.
