Thanks for solution to optra
13 years 8 months before #27257 by manual-mecanica
Thanks for solution to the Optra published by Manual-Mecanica
Friends today I took a great weight from above. Find the solution to the problem !!! And I appreciate your concern and encouragement to help me repair the car, now I told them, the car passed through 3 previous garages and they even changed rings, metals almost adjusted it in the end ... The only thing that I needed to try was the benzine pump and since the manometro was defective That the pond had sand and pebbles and at least 2 kilos of sand, clean the pond and change the pump and finally solve the nightmare
13 years 8 months before #27261 by manual-mecanica
Manual-Mecanica Response on the Re: Thank you for solution to Optra
Good afternoon, I would like to know what your opts was because I have a kia sportage that is about to drive my here is not being done and they say that the tank is dirty
13 years 8 months before #27267 by manual-mecanica
Hello, I am a mechanic and the Chevrolet Optra arrived at the workshop with a fault with many symptoms
1 at turning in idle and when accelerating it did not accelerate Petardeos and
2nd
check was turned on when making a scanner salt sala Piedrecillas in the benzine tank a little more about this is in the theme "Chevrolet optra has me crazy"
you can tell me a little more about your problem
13 years 7 months before #27293 by manual-mecanica
Thanks for your answer, I tell you what I changed: the coils, an injector and their hoses and began to smoke, they said the MAF sensor, then it was the IAC, then the oxygen, then TPS valve, then the croche valve, then I took it to another and placed a crashing a crash the injectors walked more or less until it was more or less Injectors that were very dirty and walking but continues to light check already problems to start when I turn it on and when there is tail
13 years 7 months before #27299 by manual-mecanica
Hello friend, have you made a scanner? If you have not done it, I recommend that you do it, that way you will know because the check is on and with the same scanner you can turn off the check's light if you already repaired the fault. If you did indicate that code accuses the scanner to help you more
