Thanks for solution to optra
13 years 7 months before #27322 by manual-mecanica
Manual-Mecanica Response on the Re: Thank you for solution to Optra
Generally, the game costs a lot, the most caused thing is that it is the problem of the motor temperature sensor, that is reflected in a former fuel consumption and some black smoke when walking, the excess pressure in the pump also makes this failure
13 years 7 months before #27342 by manual-mecanica
Hello, I'm going to list you the Scaner: 10-12-2010 Cod. 0100 SENOR CIRCUIT Air Flow / 10-12 P1505 Servo Down / P1508 MPS Low P0100 Air Sensor Circuit / 14-12-2010 P-1505 Servo Down, P0100 Air sensor circuit
08/04-2011 P1123 Tra-for air losses Age that of the Kia concessionaire, they did not understand it or they told me bought before and will take them for them to try which one that failed
13 years 7 months before #27343 by manual-mecanica
I do not know what happens with the mechanics from here, (Venezuela) and the KIA does not respond with how scours I did some sensors but remained the same and what is that engine sensor that you mention?, I also realize that he says that he always comes out circuit air sensor, also as you say he spends a lot of gas and smells a lot,
13 years 7 months before - 13 years 7 months before #27344 by manual-mecanica
Greetings Aura17, unfortunately here in VZLA the technical service of many concessionaires is mediocre, for now I do not know any that honors the post -sales service, it seems lack of training of technical staff for the new vehicles, for example in the Fiat they could not change the rear position bulbs (I believe by they call it lunetes) of a point 2008, when installing it they went out ... The error used to Ask for 3w. Rayones when doing services, in short, nobody escapes, there is a lot of liveliness and poor quality. And unfortunately here it is repaired by discarding pieces, let's change this to see if it is fixed, I do not say that the technique is bad, only that it is something expensive if you have to buy them and it turns out that it is not ... the excess of gasoline is indicated that some sensor is working badly or left something wrong, for giving you an example, the MAF sensor can be good, but if there is an air fuger after the sensor this is not measured and it causes an erroneous operation, which can give a wrong operation. Low signal failure code, you have to review with details the hose and wiring connections and tell us.
Last edition: 13 years 7 months before by .
11 years 11 months before #42641 by manual-mecanica
Do you know what? Since that time, the KIA was with problems, made the change of the filament of gasoline, air, and cleaned of injectors to calm down because there was no mechanic here in Venezuela that knew, it is very sad, the last samana, left me and of course they did not know what it was, And you know that Check's light that had never turned off, went out and everything is working, the sad thing is that sensor changed to a new one, maybe he was always damaged, I notify him in case someone happens to him the same
