Thanks for solution to optra
11 years 11 months before #42644 by manual-mecanica
Manual-Mecanica Response on the Re: Thank you for solution to Optra
Do you know what? Since that time, the KIA was with problems, made the change of the filament of gasoline, air, and cleaned of injectors to calm down because there was no mechanic here in Venezuela that knew, it is very sad, the last samana, left me and of course they did not know what it was, And you know that Check's light that had never turned off, went out and everything is working, the sad thing is that sensor changed to a new one, maybe he was always damaged, I notify him in case someone happens to him the same
11 years 11 months before #42651 by manual-mecanica
Greetings Aura17, I'm glad you have solved your problem, it is strange that they have not tried to replace the MAF, as you said previously that several sensors changed and nothing ... well in short, nothing better than recovering the health of the car ... greetings.
