P306 HDI Double Pump Connector and Refer
13 years 7 months before #27795 by manual-mecanica
Manual-Mecanica response on the Re: Double connector and relay pump P306 HDI pump
That relay must also feed the pump to the injectors and other sensors, you should pull the low pressure pump and leave the double relay
13 years 7 months before #27797 by manual-mecanica
throw out the low pump and leave the reverse ??? I don't understand
13 years 7 months before #27799 by manual-mecanica
This Peugeot brings bomb in the pond?
13 years 7 months before #27802 by manual-mecanica
Of course, it carries the pump in the deposit and the problem comes that when it does not start it is because it does not reach the pump since it is electric is electric pump (high pressure pump for the HDI) and the problem derives from a multiple relay that certain pins lose mass with the passage of time and I want to replace that connector and that relay but I do not know where the connector cables do you understand? Did you see the photo?
13 years 7 months before #27805 by manual-mecanica
The pump that goes in the pond is of low pressure the high pressure is the q in the distribution if it only lacks a mass of the chassis as long as only the dough is cut to the pump
