LITTLE COMMON PROBLMA, PLEASE HELP
12 years 2 months before #41466 by manual-mecanica
Manual-Mecanica response on the little common problma topic, please help
Change the thermostat.
Check the radiator electro-ventilator as indicated by the User Osvalmas that says
you fix the electro fan. It can become that it is not working properly. In most cars, the electro has 2 speeds, if it does not go down, then when it lifts more temperature lights the second speed and then the temp. You can check this with the stopped vehicle, you let it heat and when it is at normal temperature you see if the electro starts, if it does not work and continues to rise, and starts when it reaches more than 100 ° in high speed, then the first speed does not work.
The other possibility is that you arrive at a workshop that has a scanner with which connected to the vehicle can be tested the two electro-ventillator speeds,
another is that you answer the messages of the users who are helping you and if you already solved the problem, indicate by this means
help you to help you
thanks for the attention provided
12 years 2 months before #41653 by manual-mecanica
Check the water pump sometimes it is broken or the turbine of it is broken down and the amount of water needed in high is not rotated and when the revolutions lower it, check the bulb of the electros that may be that the low speed does not active
