LITTLE COMMON PROBLMA, PLEASE HELP
12 years 2 months before #41429 by manual-mecanica
Manual-Mecanica response on the little common problma topic, please help
I had that case and the problem was the Lady Water Pump
12 years 1 month before #41437 by manual-mecanica
Hi Rodelba, did you already solve the problem, how do I finish? Or you have some more data.
greetings
12 years 1 month before #41438 by manual-mecanica
Hello, because the car has a few days in the workshop, they told me today that they changed a temperature blister (I imagine sensor) and that they were going to call me to deliver it, but they realized that I lost water through the pump (of what I thought it consumed water). I believe and I hope this is the solution, when they give it to me I tell you! Thank you!
12 years 1 month before #41441 by manual-mecanica
hi, friend. I think it is the thermostate, it gives me that the Bulvo does not always sierra, luck, and to the bull a greeting ;)
12 years 1 month before #41462 by manual-mecanica
Check, that the fans jump, and that once this occurs, the two sleeves of the radiator, both upper and lower, are hot at the same temperature approx. If the operation is correct, you should change the temperature sensor, which goes in the butt, just behind the oil decanter. There is the possibility that if you have bought the second -hand car, they have subtracted kilometers, so that if the sensor was not the problem, the instrument box may be failing due to its manipulation, since these pictures are another module of the engine and subtracting kilometers, once the time is passed
