I know that everyone with a Nissan Platina has too many problems such as I had to buy a Nissan Platina in Mexico is the 2002 model and the truth has had many failures one of many and that no one has been able to solve me or in the agency is the ignition I leave the car resting and in a couple of hours when I want to turn on it, I do not click or turn Sound nothing changes the computer almost everything but yet it does not click on a sound or turn on or anything I can help me I get tired of nesecitating pushing to turn it on the battery is well too it is new the coils the coils are changed often I do not know what passes every morning that you push me to turn it out because the car is dead help me ...
Hello: You do not say what city are you in, but I would like to know if they already checked the starter engine, and the postmission of the time band, I suppose that they already changed it, if that band is a vrincado tooth, it works but with failure, it shows because in low this trembling slightly but when accelerating it works apparently well, it can also be failing the position of position of the cranker I include more to think that the starter engine does not have enough speed to start, they must be 325RPM, or the band is not exact. I am in Matamoros Tamps. Mexico, and I specialize in Nissan. I also have contact with workshops of almost the entire Republic in case I can serve you something.
Try to make a bridge between 58, that is, the cable that comes from the suichera and goes to the start when it is dead uses this cable and make contact between the battery positive and if the start works or say it better if it rotates the starter engine is that it does not arrive enough amperage to exempt the starter automatic then should put an auxiliary relay so that the necessary amount of current arrives so that the necessary amount of current arrives. Start.- Try it and let me know greetings Alf.
Hello again, answering their messages and thanking them in advance for being so kind of answering my doubts I am from Jalisco and about the second message the cable to give spark through the positive of the positive of the battery that already tries it and if it works but it is something annoying to have to resort to this medium every time I do not prefer to solve it so I will continue to continue their advice and notify them a thousand.
