intermittent jerking on Isuzu kb 260 d/c 1994
13 años 11 meses antes #23269 por manual-mecanica
intermittent jerking on Isuzu kb 260 d/c 1994 Publicado por manual-mecanica
Hi all,
this is a great site,for manuals...
can someone help...?? when driving at a constant speed, cruising,no load on the engine, my isuzu jerks intermittently,like fuel starvation.whenever it does this i give it full acceleration to see if it is a fuel shortage but it accelerates contantly with no jerking at all.
i have fitted a new fuel pump and new filters,new ignition coil and spark plugs and plug wires, new distributor cap and rotor.
this problem only occurs when your road speed is constant and you are not accelerating.
what could it be????
kind regards
chris
13 años 11 meses antes #23585 por manual-mecanica
Respuesta de manual-mecanica sobre el tema Re: intermittent jerking on Isuzu kb 260 d/c 1994
did you clean pcv valve or the egr valve something clogged in the intake system
13 años 9 meses antes #25756 por manual-mecanica
yeah clean all the sensors in the intake. nothing else ocurs to me.
