Hello everyone, I have a problem with a spark that came to me in the afternoon when scanning it, these codes
P0123
Circuit
Sensor
Circuit Circuit -52 - 51 Ignition coil P0563 High Tencion System
When the car did not start, I left the battery all night, in the morning that connects I start perfectly without failures what I see in these code is a pattern that is repeated and the high voltage that could generate it, if it is a fuse computer problem ou relayer la batterie est nouvelle. A08S3 Cylinders, Nésecito aide car après un itinéraire, je présente à nouveau la faute et je ne crois pas les composants, à l'avance.
