Peugeot 306 xs 1.6 Don't burn well and I'm crazy
11 years 4 months before #45536 by manual-mecanica
To have the distribution already thought if some tooth had jumped to me, but on the same day and gave me to look at it, that is to say, the pulley disassemble and take out the cover that covers it and examine it carefully without making it clear it only remove the cover to examine it and it is all correct but well what I tell you to start start to the first and in cold cold of the morning of the morning. On the contrary it starts to perfect and in terms of accelerating it I accelerate it in cold and it seems that it goes well but when it is already fucking temperature the engine begins to go differently as if it were 3 pistons but in reality it does not go alone that it does not burn well and smells like bad gasoline burned and when it is heated and accelerated slightly they are smelled. Only when I accelerate and when it is in relief on exploding every minute more or less but when the car is already hot One of them was a crankshaft position sensor, that is, the CKP if I am correct a greeting
: UNSURE:
11 years 4 months before #45537 by manual-mecanica
Try to look at the spark plugs when I do this, to see what is the cylidro that fails, or if they are all ... if one does not burn well, it will be more wet and black than the others, try if it turns on putting it to the dough, if it is fine, it changes the injector of that cylinder for another and looks again (to know if it is the injector that fails)
11 years 4 months before #45543 by manual-mecanica
Hi.ComProbar Admission pressure. What engine and injection you have
11 years 4 months before #45591 by manual-mecanica
Hello Compadre Look I had a similar problem and check all the sensors, check wiring and all the only thing I had was the ignition module that in the Mio case is from the TU5JP engine with Bosch MP5.1 injection which is incorporated into the computer if you know electron The manual I send you there appear the different types of injection the bosch the magneti marelli
luck
11 years 4 months before #45592 by manual-mecanica
luck
