Hello Compadre Look I had a similar problem and check all the sensors, check wiring and all the only thing I had was the ignition module that in the Mio case is from the TU5JP engine with Bosch MP5.1 injection which is incorporated into the computer if you know electron The manual I send you attached
There appear the different types of injection the bosch the Magneti Marelli
luck
