- Thanks received: 1
Maybe what happens to you is that the cable that goes inside the trunk gate is cut.
This happens of the same use of opening and closing the trunk, the cable is cut and the servo does not work, but does not jump any fuse since otherwise no door would work and you would see the broken fuse on the board under the left steering wheel on the left on the pedals.
Tip, open the trunk, throw the rear seats to theor, get into and with a breakdown patience where the cables that activate the closure of the trunk pass.
In the Opel Vectra also happens and another thing that happens to them is that the light of the trunk on causing consumption, exhaustion of the battery, failures when putting the carlarm (detects open door) etc. is left.
You will see a black hose that is taken to the gate with two plugs that you will have to change for a new one, they are not faces.
Another thing, also looks at the servo of the lock itself, it will not be that the motor has broken and nothing happens to the rest of the installation.
I hope I have helped you.
