Opel Corsa 1992: Interior alhumbrado problems
18 years 6 months before #870 by manual-mecanica
Opel Corsa 1992: Interior alhydrated problems published by Manual-Mecanica
It seems that lately I have only electrical problems. Now it turns out that when I put the position lights, or those of crossing the lighting of the panels is turned off (counting, clock, etc ...) Any idea of ​​how to solve the problem?
Thank you
18 years 5 months before #975 by manual-mecanica
Manual-Mecanica Response on the Re: Opel Corsa 1992: Interior Alhage Problems
If your car has command for the regulation of the luminosity of the instruments, it may be that.
Right now you don't tell me if it is a Corsa A or a Corsa B. and I suppose you have looked at the two fuses of 10 to (red) with the drawing of the position of position and that they are fine. If they were not, in addition to what happens to you, you would fail the position of one side of the left car. or der.
If so and it is the Corsa B, (the round) the command of the luminosity of the boards is next to the sowment inclination, under the light switch and above the antiniebla buttons, to the left of the steering wheel.
I hope I have helped you.
Receive a cordial greeting.
