If you look, the .iso file is a file of \ "image of cd \" that file you can burn in a CD with programs such as \ "nero \" or \ "alcohol 120%\" or you can use some program that emulates virtual units.
Starting from this point I will make you a small tutorial with the
Magicdisc (program with which you can open your file without necediad to burn it in some CD)
I will make you a small tutorial to use the program, do not worry, which is simple
ok, ready?
1.-
Download the program , you can go down on the main page of the Magicdisc ... that is ...
here
2.-
You install the program
3.-
Execute the program ... what happened? ... nothing?, Ok, will we pause here, take a look at \ "my pc \", if you see with care you will see that there is an extra DVD unit, you can differentiate it from the others because it has a black sign that says \ "DVD \" Did you see? Ok, let's continue.
4.- Once the program is executed, Czech to the right to below your screen, there where the time is (that is the system tray, ok? ... well). As I told you, to the Ladito of the hour you will see an icon of a little hand holding an album, that is the Magicdisc icon, do not do anything yet, just have it located.
5.-
Right click on the Magicdisc icon.
6.- Of the options that appear, place the cursor (not click, just place on the option) on
\ "virtual cd/dvd-rom \", something similar to this will be displayed \ "
not average ... \" (the \ "i \" is your virtual unit, it may not be i, it can be any other) ok? Click on \ "
Mount ... \" You will notice that the Windows explorer opens, ok, now looks for the file you want to open (in this case it is your manual.ISO) Once located, select and press Enter.
7.- Now, return to \ "My PC \" and your manual is in your virtual unit, just double click on this (the virtual unit) or, select the unit> right click> Explore and voila.
Easy, right?
