The files with extension are images of CDs, to be able to see it you have to record a CD using Nero , Easy CD Creator or some other program that records images; Or you have another option that is to use a program called alcohol 120% that allows you to create a virtual unit to load images without recording them, that is, loading the image from the hard disk with this program and this opens it as if you had inserted a CD.
