KIA Frontier II OR HYUNDAI H1 2.5 Workshop Manual
14 years 3 days before #22660 by manual-mecanica
Greetings ... I have searched everywhere and I have not been able to find the workshop manual for a Kia Frontier II ... it is 2007 with D4VH engine ... slowing down only ... this around 1200 rpm and it is unstable ... the problem gets worse when the engine is heated ... I hope you can help me ... cordial greetings
13 years 11 months before #23631 by manual-mecanica
For what you say that problem is the accelerator sensor that goes sensor goes on the accelerator pedal only you have to change it and the other does not buy it used only new
7 years 2 months before #53028 by manual-mecanica
Manual-Mecanica Response on the Kia Frontier II OR HYUNDAI H1 2.5 workshop manual
Hello: if the vehicle has more than 100,000 kl. It is possible that the Catalitian is poor and obstructs the exit of the gases normally causing excess temperature in the Lambda sensor, uncontrolling the slowdown with acceleration oscillations.
It must be remembered that the Lambda sensor cannot be exceeded from 400 to 450 degrees ℃ If this passes the sensor is damaged and the "olfatus" will be deficient causing the electrical signal coming from the computer to the IAC valve to be in intervals sequences causing the oscillation and uncontrol of El Readi.
