00 Passat does not go
15 years 3 months before #11979 by manual-mecanica
00 Passat does not march published by Manual-Mecanica
New battery does not reach current winging the relay is fine the switch sends the current to the relay how to know if it is the alarm or key of the key. The land does not get to the relay no codes with the scanner if someone can help Grasias
