DOUBT
15 years 3 months before #12057 by manual-mecanica
Doubt published by Manual-Mecanica
Hello if someone could help me, please, I would like to know why a light is turned on that indicates an engine in a Daewoo sky of 94, and next to the side there is also a light that forever turned on that is like an open book, please if someone could help me in it is afraid to see pro to turn on those lights.
15 years 3 months before #12065 by manual-mecanica
Manual-Mecanica Response on the subject Re: Doubt
The motor is check warns you of a problem in the fuel injection system, being a sky the most cause is that it is the temperature sensor, but the Scaner will tell the truth it is better to put the diagnosis machine to get out of doubts.
15 years 3 months before #12066 by manual-mecanica
It is also importing that you tell us that it fails does the car, so you don't see an uncomfortable walk or pull or anything could be the oxygen sensor. But danas more data
15 years 3 months before #12070 by manual-mecanica
Look what I feel in the march is, that when I am not affirmed and the climb is coried normal and from one moment to another the car reacts and begins to react very well.
