Temperature sensor
15 years 2 months before #12709 by manual-mecanica
Temperature sensor published by manual-mecanica
Hello everyone, I wanted to ask a question, the temperature sensors are generic for all the vehicles?
If someone could illuminate me in the subject I would appreciate it.
Greetings
Javier.
15 years 2 months before #12746 by manual-mecanica
Manual-Mecanica Response on the Re: Temperature sensor
Temperature sensors are not activated at any temperature are always in cold on hot, what you should check is the internal resistance of the sensor have ranges or scales, they begin in 4.1 homs and are lowering intimidated that the tenniscence increases, which is achieved with this, modify For this reason that when they are in poor condition the cold game costs a lot for a fuel excess, since being cut sends a starting sign of -40 degrees Celcius, get the parameters and consist them if they are the same, it serves you, but in most cases they are not generic,
15 years 2 months before #12747 by manual-mecanica
Thank you very much for the data, I find it very clear about the theme of the temperature sensor. I think it is unproven to serve me.
15 years 2 months before #12772 by manual-mecanica
Clear explanation and cencilla greetings Kikemec : Woohoo:
