Help with Atlantic
15 years 2 months before #12807 by manual-mecanica
Help with Atlantic published by Manual-Mecanica
Well, I ask for help with the Atlantic of my boss, it turns out that the speed box was madrio then we gave the box in return (the one they gave us in return if pulling was tested) then we mounted it is already put.
But the problem is that the car is very donkey has no strength is very slow (it takes to climb a climb: Dry: ) but no more grabs a descent or flat and grabs strength.
We asked several mechanics and they told us several things the joke is that we did all that they told us and remains the same.
-What out of time (we already take it and remain the same)
-Bujias (new and equal)
-Platinos (new and accommodated and equal)
-which possibly the engine does not work (they just drew it I do not think it is that)
that they believe that it can be I hope you can throw a cable to repair it from now.
15 years 2 months before #12836 by manual-mecanica
Manual-Mecanica Answer on the Re: Help with Atlantic
For any Czech doubt first the compression of the pistons which minimum of being 100 psi or already finally 90 psi, the box of your car is autometic or standard
15 years 2 months before #12840 by manual-mecanica
The box is automatic.
And look at the car is fixing everything and the engine has just taken to ring and check it is included the pistons right?
And if the pistons were the wet spark plugs of oil, right? Only wet them.
I'm wrong
15 years 2 months before #12842 by manual-mecanica
Do not need to wet the spark plugs so as not to have compression, so I tell you that you carry it with another mechanic and give you the reading of the piston compression by piston if the reading is good as I told you before, it is not the engine you can also check if the engine is revolutionized more than what is not awa Revolution is the Checalo engine and hits me is not for others then because of an oversight we can move the rings when they instill them or ay compression leak in the valbules.
