Hello. I have a Chrysler Neon Dohc 97 and after laver the engine did not start. After a while, he threw smoke and smell of raw gasoline, but all good. On the way back at 140 km/h, the oil light lit for a moment and then turned off. I stopped because there was white smoke. It was the broken oil pressure bulb. The engine did not suffer from oil because I stopped on time. The fact is that it does not start. My mechanic who has Scanner and everything cannot find the fault. Give a foul error of the crankshaft position sensor during start. Could it be that without the new oil bulb and walking, the car cannot be started?
Thank you
