Problems with the new Peugeot Boxer 2.2HDI 100C.V
14 years 10 months before #15230 by manual-mecanica
Good afternoon friends of the forum I have a Peugeot Boxer 2.2HDI 100C.V. From the year 2006 when I bought it a year, the sneak of the gas recycling valve was turned on to the workshop and they changed it to me like that they will have changed as about three times now has had lost power with pulls when it goes up and pulls me a lot of black smoke according to the performance of the motor The same, another diagnosis was made and the catalyst came out, it remained the same, and finally another diagnosis was made and the caudalimetro came out, but it is still the same as the computer has nothing right, if someone could help me with this problem would be grateful a greeting to all of the forum
14 years 10 months before - 14 years 10 months before #15268 by manual-mecanica
Possibly have a problem in the vacuum hoses that motor actuators move through the solenoid valves.
I explain myself, the management of the turbo, the EGR, and something else, goes by emptiness through solenoid valves.
If a solenovula fails, an unequivocal code appears automatically in diagnosis (EGR actuator failure ... Falling Pressure Actuator failure ...) whatever.
Peeeero if a vacuum hose fails or if the engine vacuum pump sucks little, the solenoid valves work, but the problem is that the actuators do not move on time !!
So: the EGR fails because the switchboard orders to open it but it does not open, or not as it should, the turbo feed pressure fails because the lung that limits the blow is operated by emptiness and does not work correctly ... the flowmeter fails because it measures a lot of air (when the turbo blows and does not touch to blow for example) and gets out of range ...
summarizing, fifty failures and none is 100% correct. All for a fucking plastic tea that has broken or for a shit tub that has fallen ...
the first thing, check all the tubes that leave the vacuum pump and check with a vacuometer that there are no vacuum leaks or perforated membranes in the actuators.
Another thing that gives enough war is the intercooler, sometimes it is drilled or slit, or some turbo sleeve is broken and causes the compressed air of the turbo to escape to the street. This causes failures in the feed pressure sensor, black smoke, failures such as the flowmeter is wrong or as the EGR is damaged.
To rule out this, apart from visually checking the sleeves, the intercoler exit mushy is touched to the intake manifold, the flowmeter is disassembled and another plug is put in the sleeve that embraces the flowmeter.
Then the 1.5 bar sleeves are pressurized at most and if a pffffffffffff (blow by somewhere) is heard, it means that we have found the breakdown.
If you had started there, you would have saved money.
All the best.
Last edition: 14 years 10 months before by .
