Hello good morning, the fact is that I have an Audi A3 8p with BKD engine, the car was left without oil pressure, and as it is general, I was left without lubricant in the rod and bench bushings and I need to know that tightening pairs carries, I am not very expert in the subject, and I would also want
Or you ran out of oil or the pump is wrong. The cylinders check them, all crankshaft caps and changing cams, butts, seal and lucky the turbo will be fine. Remember that cylinder heads are loosen in a spiral or cross very gradually the time to press the same. I hope the photo serves you.
