disassemble the Peugeot 206 Radio housing
16 years 10 months before #4066 by manual-mecanica
Disassemble the Peugeot 206 Radio Housing Published by Manual-Mecanica
I need someone to help me disassemble the Peugept 206 housing to change the radio, Greetings Thank you
16 years 5 months before #6141 by manual-mecanica
Manual-Mecanica Answer on the Re: Disassemble the Peugeot 206 Radio housing
Hello,
withdrawing the radius of 206 is simple, only some type of rigid wire in each of each of the corner is in each of each corner and they throw the insurance, if you make a small hook to one of the wires you can pull it, I hope it serves you
16 years 5 months before #6152 by manual-mecanica
I imagine that to disassemble your radio, \ "u \" are needed as the partner says "Davidmanual \" you can incert some type of wire. I recommend that you wear the legs of some old glasses and the doubles in \ "u \"
16 years 5 months before #6164 by manual-mecanica
I believe to understand what you say what you want is to remove the entire beast part to work in peace and with more careful truth, ok, the fragrant part where the clock is only enfutid The upper part, beware of the radio cables, if any positive makes you contact with earth, and you will burn a yellow 20 amperes fuse, which serves for the start. I have forgotten the yellow and red cable of the vehicle cables go together in the radio,
