Toyota Hi Lux 1997
10 years 8 months before #47617 by manual-mecanica
TOYOTA HI Lux 1997 Published by Manual-Mecanica
Dear gentlemen I have problems with the gearbox, when connecting the 4x4, jumps and disappoints.
10 years 8 months before #47618 by manual-mecanica
Manual-Mecanica response on the topic Toyota Hi Lux 1997
Coupling fork problem or too much game in the 4x4 lever couples, coupling piñon wear, fork. Look at the displacement from the coupling lever to the 4x4 drive input, look if you can connect it manually below the vehicle, trench metelo for a better job and someone helps you move the lever
