P0025 A P0025 code refers to the VVT (variable distribution) or APV components (synchronization of the variable camshaft) and PCM of the vehicle (power train control module, also called an ECM). Consisting of different components but the DTC P0025 specifically refers to the camshaft (cams). It refers to the LEBA that goes to the exhaust tube check incorrect camshaft tree wiring problems (harness / wiring) in the control system solenoid valve of admission time control
time Cams are controlled by hydraulic actuators fed by the engine oil system through control solenoid by the control module / engine control propulsion system (ECM / PCM). The ECM / PCM has detected the movement range of the intake camshaft at Bank 1 is out of specifications or does not work when commanded. Bank 1 refers to the motor part with cylinder # 1 - Be sure to verify which side is correct according to manufacturers' specifications. The intake valve control solenoid is normally found on the side of the cuisine intake manifold. Check manufacturer specifications.
Among the possible causes of a P0026 diagnostic code may include: Low engine level of the motor or incorrect oil or incorrect oil system obstructed The malfunction of the control solenoid The malfunction of the camshaft actuator distribution chain / lazy or bad strap chain The malfunction of the ECM /
PCM
