Injection pump three cut cables.boxer2.5 1998
10 years 7 months before #47983 by manual-mecanica
Injection pump three cut cables.boxer2.5 1998 Published by Manual-Mecanica
Hello good.
Let's see if someone can solve a doubt.
Peugeot Boxer 2.5 D 230L 1998 86 hp.
I have found the three corted pump cables.: EVIL:
The issue is that 3 cables come out of the pump and they go to a connector, one yellow and red, another gray and black and one brown.
They are cut at the same distance so I paint the three to the same place.
I have located a connector with two of the three cables red and the black gray and looks like a third terminal but I am not sure. But there is a hole that can be.
I have been checking if I saw the brown brown cable somewhere and I don't see it.
I have searched for photos or some solution and I do not find it.
Since it is the bomb and if it is hindered it will be a fun repair because I prefer to ask. I do not risk starting only with two cables for what can happen.
If someone knows how to indicate a little, I think it is clear but if any photo is necessary or something without problems.
Thank you.
10 years 6 months before #48003 by manual-mecanica
Manual-Mecanica response on the topic Injection pump three cut cables.boxer2.5 1998
If you put the photo then better (of the pump and the cables that leave it) I have seen cables disconnected in a bomb of the Berlingo and worked well, I think they were cut because a corrective electrovalve of progress in cold progress did not work but I no longer remember well, if we see it, then better. Greetings!!
