mechanical problena
10 years 6 months before #48001 by manual-mecanica
MECHANIC PROBLENA Published by Manual-Mecanica
My car is a Seat Cordoba 1.9 TDI Motor Axr had an accident but now that I want to start it appears to me a failure we put it in a diagnostic machine and three fault codes appear to me are 00771, 01316,01309 If Algien could tell me what it means it is very grateful
10 years 6 months before #48002 by manual-mecanica
Manual-Mecanica Response on the Mechanic Probelena
In the obd II codes this appears: 771- CHANGE AND ELECTROVULVULA ELECTROVUL Rotating VALVE OF THE DIRECTORS, Rueda Coats etc ... or the failures it throws are derived from the accident and have no relation to the address. Try to reset the ECU and return to make the diagnosis to see what comes out. Greetings!!
