Ford Focus 1.6 16v 2001 starts badly.
7 years 10 months before - 7 years 9 months before #52496 by manual-mecanica
Ford Focus 1.6 16v 2001 starts badly. Posted by manual-mecanica
Hello, I have a problem with my focus, Hos commented. When I try to start it in the morning it costs him a lot but it ends up, it stays like 3 cylinders but as soon as the accelerator is playing, his wobbread is removed. Because he warms herself as false splesions and in low revolutions he tries to relate, but in the high it goes very well.If I take the contact and then give him the first. But if I wait 10 minutes it costs you again to start.
The relash valve, the body of butterflies, the Motorkaft camshand and spark plug sensor are new. They are not found empty leaks. No one marks any fault code.
Apart from the spark plug cables. What else can I look at him? THANK YOU.
Latest edition: 7 years 9 months before by .
7 years 10 months before #52527 by manual-mecanica
Manual-Mecanica response on the subject Ford Focus 1.6 16V 2001 starts badly.
Hello, you have to reset the self -adaptive parameters with the scanner for starting greetings
7 years 10 months before #52529 by manual-mecanica
What engine does and how many km do you have?
7 years 9 months before - 7 years 9 months before #52562 by manual-mecanica
As in the matter, it is named is a Ford Focus 1.6 16v Zetec are sedated 100cv. FYDB1 motor code 2001. And it has 104,000 km.
For saying more. New coil and cables. The strange thing is that when the new coil was put on, the first start was instant.
Can you give me any subject? .Thank you.
7 years 9 months before - 7 years 9 months before #52563 by manual-mecanica
Can you reset the auto-adaptive parameters without the scanner?
For example releasing the negative of the battery for a few hours to reset the switchboard?
