Help with Hyundai H1
16 years 9 months before #4535 by manual-mecanica
Help with Hyundai H1 published by Manual-Mecanica
I have a Hyundai H1, the problem is that the engine should supposedly stay on for a minute after taking out the keys and my van stopped doing it.
My query is how it can be fixed and if there are consequences.
I hope you can answer me, I would appreciate them.
16 years 7 months before #5282 by manual-mecanica
Manual-Mecanica Response on the Re: Help with Hyundai H1
Greetings, in reality it is not when you take the key and much less a minute, in the version before 2008 (and I say before because I fall out that version 08 and 09 has it), the engine remains on only a few seconds after returning the Swich of its ignition position to the stand by position. By this I mean that if your van does not remain on after you withdraw the Swinch key, it has no problem.
Greetings and I hope you are fine.
16 years 7 months before #5285 by manual-mecanica
Hello kaisero, see if this happens to you that your H1 is equipped with a turbocharum, now if you stop official you would have to check the electrical system I bone the wiring of this if everything is ok, you will have to change it are not very expensive and sell kit to install them is relatively easy to perform this task, check the relay if you possess it but the fuse, the fuse must Autodetion, they are generally focused on a deterioration of the Turvo and its breakdown, you can decrease this risk in a simple but uncomfortable way, make the vehicle stop the vehicle you have to leave it in relief 1 minute or until the Turvo stops or its revolutions fall, it is that for the moment the Timer changes and this is already faster and less problematic.
