Mechanical shutters are formed by a rigid hollow body formed by two extreme plates linked by a diameter cylinder lower than the extreme plates, among which is a fan annular bladder of a cat that extends around the cylinder. The cat inflates to apply a cylindrical wall against the internal surface of the pipe wall. The wall that is independent of the cat bladder can be connected by its ends to the extreme plates or can simply be inserted between them.
