Daewoo Lanos Problem 1.4 Year 2002
16 years 7 months before #5196 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Daewoo Lanos 1.4 Year 2002
One question you have installed some accessory inside the car or outside in these days it can happen that installing it have left some cable and is creating that problem, it can be the pump as the classmates say but explain well what is the fuse that jumps you because normally the pump relays has its fuse separately or is a fuse of the car fuser.-
16 years 7 months before #5209 by manual-mecanica
The fuse that jumps is from the rifle, the one that directly feeds the bomb (it seems, I am not an expert). The mechanic has told me that the pump relay is not, that he thinks it can be or the pump itself or a component of the feeding system that does not know where it is.
Three months ago or we installed an interior radio antenna, and the problems have started a month ago, the mechanic has told us that it has not been that, that they are different fuses.
On Monday I will not know if he has done something with the car, I'll tell you.
Anyway, thank you very much for all the answers.
16 years 7 months before #5237 by manual-mecanica
Hello, look at the problem is in the passenger part where we support the feet. It is a red wkpower when rubbing with the pump fuse japs, it usually happens when it puts the feet in that part.
16 years 7 months before #5241 by manual-mecanica
Tell the Mueanic to check first of all the wiring, do not be fooled.-
16 years 7 months before #5279 by manual-mecanica
Betis, where is the red cable that you say it makes it jump?
Greetings.
