I have problems with my Chevrolet Blazer 97
16 years 7 months before #5287 by manual-mecanica
I have problems with my Chevrolet Blazer 97 published by Manual-Mecanica
I am new in the forum and I ask you the following problem:
the truck did not start and from so much I started but I miss a large amount of white smoke because of the escape. I did not maintain the minimum of acceleration until I made a long journey, where you notice that the white smoke was removed and kept the acceleration. After the trip, when I try to start it again, it makes exploits in the carburetor but does not start the engine.
I appreciate any information to solve the aforementioned problem.
Thank you!!!
16 years 7 months before #5305 by manual-mecanica
If your truck is not injecting, it is surely out of point, controls the set -up of the distributor by lamp, if you touch, as you say that it makes counter -eating in the carburetor, cross the cables of the central cylinders, that is, it puts the cylinder cable 3 in the 2 and vice versa, go and give it some accelerated, put it correct again and if it improves the tank. 10% of the load in acetone, walk a little to be cleaned, but set the tuning because it must be late ...
Salu2
