hello!!!! I have a Fiat duchato that loses me hydraulic liquid by the zipper (it does not retain the liquid that I add for the great loss it has). They advised me not to move it (to take it to the mechanic) with the empty hydraulic pump. Is it true that I can't move it? If so, what can I do ???????? They can facilitate some hydraulic bomb manual or give me some help or idea. Thank you for your time when reading this consultation :) and I hope your answers, yes
The ideal is not to move it for the use of the pump without liquid makes the inside of the pump wear. If the route is not very long, you can move it, look if it has an outer strap you can take it out and move it without the strap, as long as the belt only activates the hydraulic pump.
Message originally written by Roberto Artemio. Thanks Pacchin for your answer. The pump has no strap, so I saw is connected to the engine. Now I ask. It can be created a closed circuit of the hydraulic fluid that goes from the pump to the zipper (that is, the zipper is canceled by joining the magueras with a pipe that allows the hydraulic fluid to circulate, of the pump towards the same pump). Is this without the pump without hydraulic liquid. Please I wait for your answer or that of someone else's forum.
