Light Liquid Level Refrig
16 years 7 months before #5290 by manual-mecanica
Light Liquid Level Published by Manual-Mecanica
Hello
when I start in cold, the light of the refrigerant liquid and the oil of my toledo 1.6 oil are lit,
after a while when they heat up they go out. I have consistent all levels and they are fine. What can be? I would appreciate a advice apart from taking it to the workshop. Thank you
16 years 7 months before - 16 years 7 months before #5304 by manual-mecanica
Manual-Mecanica Response on the Re: Light Light Liquid Level
Hello, you can tell us what year is Toledo. I have one of the 93, and I am also illuminated by the light of the painting, these cars fail a lot about the light box, the sensor that carries in the expansion vessel is also spoiled.
Latest edition: 16 years 7 months before by .
16 years 7 months before #5312 by manual-mecanica
Hello, how are you:
the car model is Toledo 1.6i Year January 1993.
I have tried to look for the failure, removing the sensors cables, reviewing the fuses ... etc peromlas lucecillas are still when I start for +- 5 minutes.
all the best
16 years 7 months before #5313 by manual-mecanica
January 1993 1.6i. I have tried almost everything, remove sensors, check fuses ........ etc. How do you see it?
all the best
16 years 7 months before #5314 by manual-mecanica
Hello, is the temperature needle stable all the time? or is it oscillating?
