Moists very black when this happens? Do you have the black car culera? Do you hear a pssssssss from time to time?
The ruling may have it in some sleeve of those who go from the turbo to the intercooler and the intercooler to the admission manifold, or that you have the intercoleer cracked (less likely, especially if you have not given any blow).
To check it, you have to keep the engine accelerated at about 2000 rpm and pass the hand through the pipes, it is easy for the sleeve to be with the EGR is cracked and when the turbo blows strong, the slit opens, the air goes out, the flowmeter error gives the flowmeter, the fault witness and the car \ "is shit \".
If so, you did not find the failure, with the engine stopped and cold, the escape with a rubber glove and packing tape (seal). Then take away the rubber sleeve that comes out of the flowmeter and do the same (put another glove and pretend so that the air does not come out).
Then you put compressed air with the help of a compressor and a gun or a gossip of giving air to the wheels do not pass from 1'5 bar). And with the help of a spray of cleaning crystals full of water and dishwasher, spraying on all the intake tubes and on the intercooler. If bubbles come out from somewhere, it is because you have an air leak, and that is the problem.
Another thing that also happens is that the EGR is seized and open, so that the exhaust gases pass to admission without any control.
To check it, with the engine stopped and cold, you disassemble the EGR from the intake manifold and with the help of a very fine sheet, (such as a drink of soda) you make a joint equal to the one it has, but without the gas passage hole. The idea is to plug it to avoid the exhaust gases to admission.
Next, you go to try the car and if you stop giving the failure, you have the problem in the EGR, now you have two options:
1st Leave it as it is, (with the blind joint), mechanically it is not harmful, it even is one more tad, but it is more polluting because it produces nitrogen oxides.
2º Buy an EGR valve and assemble it.
Greetings and you'll tell me.
