New Scenic
16 years 5 months before #6138 by manual-mecanica
New Scenic published by Manual-Mecanica
I do not see how to remove the filter from the air. Do I have to release the battery?
16 years 5 months before #6153 by manual-mecanica
Manual-Mecanica Answer on the Re: Scenic New
What type of motor tine your scenic if it is diesel or gasoline if it is gasoline like the image that are of the type (K4J), (k4m), (F4R); you just have to remove the resonator (locked in red) that is subject by an elastic band (blue arrow) and then remove the four screws that hold the filter cover indicated with dark red (two top and two below) Thorx Luck
Note: If this engine is the one in your car, it is the same as the Nissan Platina brings like this, it will serve the manual of this car. It is here on the page.
16 years 5 months before #6154 by manual-mecanica
Perd but in the previous message the imag was not uploaded. : P
16 years 5 months before #6155 by manual-mecanica
Well I couldn't raise it but the attached forgive the inconvenience.
ATTACHING FILE:
File name: 3809.jpg
File size: 50.36 Kb
16 years 5 months before #6159 by manual-mecanica
I have lowered the manual is made. Thank you for answering
the model is 19dci 125
