Please help
16 years 5 months before - 16 years 5 months before #6186 by manual-mecanica
Help why published by Manual-Mecanica
Good night and happy year to everyone, I need informative help and for what I see you understand enough.
I start, I have a Renault Super5 GTD (F8M 1.6D Motor) without engine and I planned to mount the 1.9TD of a Renault19 (F8Q Turbo). Now comes the problem,
-The chassis motor block seats are the same?
-I could put the engine without having to change the front cradle?
-In the case that it is worth it, what phases would be optimal for change?
-Ademas del Clio 1.9d phase1 are there any more compatible?
Greetings and please I hope you can solve the paste.
I forgot to comment that I have already downloaded and reviewed manuals in this regard and the F8M motor block and the F8Q Turbo seem the same.
greetings
Latest edition: 16 years 5 months before by .
16 years 5 months before #6224 by manual-mecanica
Manual-Mecanica Answer on the Re: please help
Sometimes they seem the same but either they see the grip points of the supports and then go with the access that each type of motor brings to you, greetings
16 years 5 months before #6231 by manual-mecanica
To that I was referring, in the manuals of both car comes drawings of the engines but come in different perspectives.
If any of you have photos or measurements of any would be very appreciated
16 years 5 months before #6252 by manual-mecanica
In principle you should not have a support problem, but you can have them in electronic management, nothing ahead with the challenge is easy
