how to start a Nissan Vanette
16 years 5 months before #6207 by manual-mecanica
How to start a Vanette Nissan Published by Manual-Mecanica
It has battery, the fuses seem to be fine, it is diesel, but when I give the contact or turn the box or pull the start or give the inertmittes, but it has lights and sounds the horn.
What can happen to you?
16 years 5 months before #6208 by manual-mecanica
Manual-Mecanica Answer on the Re: how to start a Nissan Vanette
Check the main fuses or terminal
16 years 5 months before #6212 by manual-mecanica
What is the inertial switch? The fuses have reviewed them and they all seem good
16 years 5 months before #6213 by manual-mecanica
It must be in the engine area and it has the upper red part and it is square also checks the cables that come from the positive of the battery they bring connectors that tend to interrupt or disconnect, but that no current comes to the internal part or something works for you
16 years 5 months before #6214 by manual-mecanica
You have reviewed the main fuses that are inside plastic boxes that go a positive thick cables of the battery and apart that is the first time that makes you this defect or has already done it several times
