how to start a Nissan Vanette
16 years 5 months before #6236 by manual-mecanica
Manual-Mecanica Answer on the Re: how to start a Nissan Vanette
Check the harness (Harness) that is below the board is the one that gives the power pill, directional and other accessories found in the spine of the steering wheel, clean it with carbuclean (carburetors cleaning) it dried it and then rocky with silicon fat there you must have the false contact.
Greetings
Alfredo
16 years 5 months before #6241 by manual-mecanica
If you do not get current to the starter lock, you will have to look in the car documentation where the fuses and relays boxes come, since it usually carries two, one inside the cabin and one in the front vain.
It would also be interesting to say if it is an ancient Vanette, or if it is a Vanette Cargo / Nissan Serena. Because there are things that change from one to the other.
Another thing you can do is get a fat battery positive cable and try to feed the Bombín terminal to see if you have contact and start.
If you respond, you have the failure between the starting hype and the positive cable that feeds it through its corresponding fuse. (Look a look at the connectors' chips as the companions say that sometimes they give a lot of war).
All the best.
16 years 5 months before #6267 by manual-mecanica
Thank you, I will try tomorrow and you will spend something, by the way, several cables arrive at the start bombin, don't you mind giving common to each of them? and see what is the start or I have to know in advance what is the start.
